Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Changing color of a Lense
Old 03-20-2007, 03:35 PM
docvette's Avatar
docvette docvette is offline
Wiki Edits: 12
Originally Posted by Bill Ford
How would a red bulb in a clear lense look for a third brake light?
Any other ideas?
Doc here,
Be advised, In most states, except for backup lamps and cargo's..it is Illegal to have white lenses to the rear..
We have a company here (and I think they are national) Called TAP plastics..you can walk in with a part, and your ideas, and punch one out for you in a few days..for a few bucks usually for small things..
OR cheaper yet, just buy a third brake lamp kit..
Whatever you end up doing, Be sure the third lamp has proper isolation from the turn-signals or you can end up with 4 ways every time you turn a corner..run your power wire to the brake lamp switch, NOT the light harness..
Doc
