changing control arms
I will be working on a 62 falcon 2 door sedan and I want to change the front suspension. I want to take tubular uppers from a mustang 2 suspension and put on, also using a coil over shock mounted to the lower control arm passing through the upper and attaching it to new brackets welded to the frame, and finally use 63 falcon upper and lower ball joints to change the 4 lug system to a 5 lug mustang2 spindles and bracking system.
Am I correct by thinking this will all work?
