Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - changing control arms
Old 09-19-2010, 09:48 AM
matt167 matt167 is offline
Wiki Edits: 31
I'm really not sure what you're trying to achieve. tubular control arms are available for '63+ Falcons, but will work on '60-'62's as the control arms/ balljoints are what was changed for '63+.. disc brakes doesn't require mustang stuff.. actually Granada disc brakes are cheap and effective bolt ons for '63+ ( once you get your control arms/ balljoints changed ).. you would only need a tierod sleeve adapter because the tierods are diffrent threads '65- up....
front suspension/ steering generally interchanges with the following because they are all 'Falcon based'
'64-'68 Mustang
'63-'69 Falcon
Ford Maverick
Ford Granada
