Changing Differential Gears - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2010, 05:02 PM
bosco200's Avatar
Ok I have a 1972 C20 Chevy with 4.57's its got a granny low......that is way to low for me I am going to be putting in a 350 or a 400 in it and I am wondering what would be some good gears to put in the rear end to get me some good top end speed but I dont want to loose all my torque. Thanks.
Old 04-08-2010, 05:38 PM
big gear head's Avatar
High Performance Rear Ends
Something in the 3.70 to 3.50 range should be good.
Old 04-10-2010, 09:19 AM
bosco200's Avatar
How much does it usually cost and is it hard to make it Posi.
Old 04-10-2010, 11:00 AM
Labor to change gears usually runs around $250 to $400 depending on where you are. I'm assuming that your truck has the 10.5 GM rear end, but it could be something different. I don't know what is available for the 10.5, but I can check. I know that there is a Governor Lock and Detroit Locker for it, but I don't know if Eaton makes a Posi for it. You could also have a Dana 60, which has several differentials available for it.
Old 04-10-2010, 11:25 AM
bosco200's Avatar
I know I dont have a Dana 60 I have a Eaton ....the rear end cover is completly round like a bowl.
Old 04-10-2010, 11:45 AM
I don't know anything about that rear end. You might want to change it over to a later model.
Old 04-10-2010, 01:12 PM
malc's Avatar
Living At The Speed Of Life
Search your vehicles needs here, Randy´s Ring and Pinion.
Old 04-10-2010, 07:54 PM
prostreet6t9's Avatar
Differential/Driveline
That should be the Eaton HO52/HO72. Round back cover with a drop out third member correct? Gear sets for these are getting hard to come by.Especially a higher ratio like your wanting. At one time Precision gear was doing a 410 ratio but it seems like they might have stopped.
The common ratio for these is a 456 and 513 and some 410's. The 410 ratio is really hard to come by. You might have better luck looking for a Dana 60 out of those years then you would have all the ratio options you need.
Old 04-25-2010, 11:42 AM
bosco200's Avatar
Yea I its the Eaton HO52/HO72 like you said so I would be able to get like 3.56 around there...cuz i want to get out of the 4's.
Old 04-25-2010, 11:43 PM
kpcrossfire6's Avatar
I have a 72 c/10 pickup 350, 3.73 eaton posi 12 bolt rear end. Iwont go any lower or higher to be honest, mines great.
Old 04-26-2010, 04:15 AM
The '71 3/4 ton I had, was a 350/granny (compound first), with a Dana 60 (4.10). With the 28"-29" tires I had on there, 55mph (give or take a few MPH) was around 2700-2800 rpm. Not sure how accurate the speedo/tach was, and not gonna bother to do the math right now. Just reporting what I remember. Is that the kind of RPM/speed you're looking for? I'm guessing you have coils/trailing arms, and not leaf springs out back?
Old 04-26-2010, 03:44 PM
You won't find one of those HO72 diff's in the ratio your wanting. Your best bet would be to look for a Dana 60 like a1supersport has.
Old 04-26-2010, 03:49 PM
bosco200's Avatar
Alright Thanks.
Old 04-26-2010, 03:51 PM
Sometime in the '80s the light 3/4 ton started using a 9.5 inch 14 bolt rear end that has semi floating axles. If you are just using this as a hot rod and you don't do any heavy hauling with it then this rear end might be a better way to go. These rear ends are lighter and plenty strong. There is a Eaton Posi available for them and they use 6 lug 33 spline axles. Your truck would be faster with one of these rear ends, and most of them have 3.42 or 3.73 gears in them.
Changing timing gears. ggarvey Engine 3 11-12-2006 09:36 AM
Change 4.11 to 3.08 rear end gears cares Transmission - Rearend 4 08-13-2006 01:46 PM
Differential noise after warming up? frankenvette Transmission - Rearend 3 07-08-2004 07:05 PM
changing gears 1980Impala Transmission - Rearend 3 03-24-2004 10:14 PM
New rebuilt 350 smoking when changing gears? shockers69 Engine 9 01-17-2004 07:08 PM
