changing engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-12-2003, 10:49 AM
jimbobneutral's Avatar
changing engine
i want to change a 350 smallblock GM to a big block 440 mopar, what kind of safety things should i worry about and what problems could i encounter?
Old 12-12-2003, 02:13 PM
Rubberman2003's Avatar
What kind of power diffrence is there in these motors? What kind of car is it in.
Old 12-12-2003, 02:14 PM
Tazz
safety things? none that I can think of, go to it. Don't worry be happy!
Todd
Rat Rods Rule!
Old 12-12-2003, 03:50 PM
The reason i was asking was, Just make sure your rear end and stuff can handle the power of the new engine.
Old 12-12-2003, 04:45 PM
Stitch's Avatar
Power difference !!!, everybody knows that if the driveline has lived behind a 350 Chevy it'll have no problems with a 440 Mopar
J/K all you Mopar guys don't send the lynch mob after me
Old 12-12-2003, 10:17 PM
poncho62's Avatar
Wiki Edits: 5
My thoughts exactly.................
Why would you want to do that??????
Ontario Rodders
Old 12-13-2003, 08:51 PM
Meka's Avatar
Move
Over
Power
Aproaching
Rapidly
Old 12-14-2003, 01:40 AM
Crazy Mopar Guy's Avatar
If your pan's sump is at the rear, you can use a truck pan and pick up tube to move the 440's sump to the rear, as a 440 passenger car has it's sump in the middle.
The oil pump to steering box should be looked at- oil pump is external on a 440.
What kind of vehicle are you thinking of changing the engine in?
Old 12-14-2003, 06:30 PM
car
the car im putting it in is a 1981 camaro z28
Old 12-15-2003, 03:47 PM
Gettin a life..Goodbye
You should always be cautious of being rear-ended while sitting on the side of the road waiting for the wrecker. Maybe some reflectors or reflective tape in a nice mopar color!
Old 12-15-2003, 04:15 PM
Magnus_Jager's Avatar
Tow Chainer
Last wiki edit: Rebuilding an early Hemi engine
Last journal entry: cruise pics
Wiki Edits: 2
Big mopar fan here, but I think a 440 in a z28 is fair payback for all the old mopars forced to suffer under the yoke of a SBC 350... (Slow Broke Chevy)
Number one reason I've always heard was 350's are cheap and easy to get parts for.
Well if cheap and easy's what your after More power to ya.
Now lets be nice and agree to disagree.
Honestly I'd say the 440's more trouble than it's worth in this case. Do able, but if you decide to sell it later your going to have a hard time doing it for what you invest. Making it look right under the hood is going to be another issue.
Swapping in older cars is easier because there is less to deal with, more space, less electronics, fewer parts to work around, such as power brakes, and suspension.
You are looking at having to change motor, transmission, driveshaft, fabricate some kind of mounting system for engine and trans, Custom exhaust, Ignition system, Some way to hook up your speedometer, plus many other items you never considered, such as hooing a mopar starter to a GM system.
If you do it and pull it off great love to see it, but it's a bigger project than you may realize.
Old 12-15-2003, 06:18 PM
We actually have a 2nd generation Camaro with a big block MoPar running at our local track! Strange?
Old 12-16-2003, 01:40 PM
comet boy's Avatar
When all else fails burn it
Last journal entry: more hiding stuff
I believe your wieght distr. will be way off. It will be way front heavy. you might have to change the springs in the front end. You could probably do some major burnouts though. but I would suggest a Ford 351W But when it comes down to it you can do what you please.
Old 12-16-2003, 03:55 PM
Mopar in a second gen *cries*
But hey whatever floats your boat.
