When I bought my hot rod, there was a Fram HPG-1 fuel filter on the car. Does anyone know the proper procedure for changing the filter inside? Thanks a ton.
Loosen the center bolt that is in the center of the mounting bracket until you can turn the canister and unscrew the bolt or the can until it comes off. Clean out the can and replace the o-rings and reverse the process.
You will want the tank empty or a way to pinch or plug the feed line or it will siphon fuel if it is mounted below the fuel level.
the replacement filter and o ring kit is available from most major auto parts suppliers under fram #hpgc-1.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
