Changing to fuel injected, maybe! - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2010, 07:29 PM
I have a nice 360 mopar,less carb, and I have a 4.3 chevy that is complete. My question is, what all would I need to convert my mopar to fuel injected, by using all of my chevy 4.3? Advise, thanks, Dana
Old 02-02-2010, 07:38 PM
You would need the injectors from a 350 Chevy (the 4.3 throttle body is otherwise the same), all the sensors, the wire harness, the ECU, the fuel pump (15-20 PSI for TBI, not the more common 40+ PSI), an adapter plate to bolt the throttle body to your intake, an electronic distributor that uses the HEI module, and a custom PROM for your application.
Old 02-03-2010, 11:13 AM
texas97z's Avatar
Last journal entry: A little progress and maybe new paint
x2, but there is an alternative to the custom tune. When you look at the limitations of the factory GM TBI ECM, there can be a lot of trial and error involved with custom TBI swaps, especially on to a non- GM engine. There is a guy who takes your computer, and does away with the chip(prom) setup, and uses his own hardware and program to make a computer that learns as you drive.
I am going this route with my scratch build because when I added up the cost of sending and resending a few times the chip + the $50 each time to reflash, I am not spending that much more and getting a way better product. His website is www.dynamicefi.com. I would send him an email. He always got back to me pretty quick when I had a question.
Hope that helps,
Josh
Oh yeah, make sure you get the right fuel pump. I think if I remember right 94 and 95 small block v8 trucks actually had higher psi than the usual 15psi and I think the big block trucks may also have had a higher psi also but not sure on that one. My point being don't just get one that is "for TBI", cause there were a couple of different ones. The v6 and l4 were all 15 psi as far as I know
Fuel/firing Problems with Fuel Injected TPI engine 87 camaro z28 chevcamz28newbie Engine 10 06-13-2009 12:03 PM
383 SBC, need input for performance issues roxanne68 Engine 24 08-08-2007 11:06 PM
carburetor leaking; fuel tank needs cleaning islandman General Rodding Tech 7 03-17-2007 06:03 PM
fuel injected to carb . 78 camaro isleofwight Engine 3 06-11-2004 06:51 AM
Carbed vs Fuel Injected Guitarman Engine 6 04-26-2003 02:56 PM
