IF you are installing a new cable with a rubber sealing sleeve ( not O ring)... the sleeve is installed into the trans case first... then the cable end lubed up slides in
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Also, make sure you unhook it from the engine first.
Thanks guys give it another shot this afternoon. Once i removed the bolt and pulled it up fluid starting running everywhere so i thought i would check. Thought if i was going to get fluid all over me and i was going to have to drop the pan might as well wait. thanks again.
| persistent kickdown cable leak, th350 | matt_ramsey | Transmission - Rearend | 17 | 09-19-2007 01:31 PM |
| turbo 350 on a TPI motor?? | punk1c5040 | Transmission - Rearend | 2 | 01-11-2006 09:19 PM |
| turbo 350 detent cable replacement | henryg | Transmission - Rearend | 4 | 12-07-2005 07:50 PM |
| TH350 Kickdown cable | dawg | Transmission - Rearend | 1 | 10-04-2004 01:20 PM |
| Turbo 350 | 1980 Malibu | Transmission - Rearend | 14 | 07-27-2003 04:24 PM |
