CHANGING "Lifters" - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2006, 05:01 PM
James medley (jim dandy)
CHANGING "Lifters"
I had a total of (5) lifters to go bad (stampted retainers) cracked and came out of the lifters. this is second posting.
My question is: will swaping or changing lifters cause a drop
in oil pressure? I have a high volume "melling" pump. Before
changing lifters at 60mph I had 55psi. (at 2400 rpm) Now I have about 42psi same speed @ rpm. the lifters changed were "edelbrock" to "doug herbert" any comments sugestions, welcome. as always hotrodders
Old 12-23-2006, 06:21 PM
Are they an anti pump up lifter? Maybe the bleed rate is high enough to cause a loss in oil pressure. I seriously doubt it though.
Changing pan gasket on 350 chevy rapsag Engine 16 08-04-2005 07:55 AM
changing engine wiring harness, ran into a lil problem ikeaguirre14 Electrical 9 06-02-2005 05:01 PM
What is involved in Changing Camshafts? rick458 Engine 12 01-27-2005 07:56 PM
changing gears 1980Impala Transmission - Rearend 3 03-24-2004 10:14 PM
Changing to an auto from manual in 57 Chev pikalpha Transmission - Rearend 3 12-14-2001 05:30 AM
