Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Changing My Rear End gears ...chevy truck
Old 06-28-2009, 07:37 PM
6426yy's Avatar
6426yy 6426yy is offline
Swap the whole rearend, then when you do your V8 swap and put an overdrive in it you can put the original rearend back in. This would probably be easier/cheaper than setting up the rear with a new ring and pinion. A 3.07 rear shouldn't be hard to find especially if your truck has leaf springs.
