Changing orientation on RNP - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2013, 02:11 PM
Hopefully this is not to difficult a question. I am installing a center steer rack on a modified S-10 frame which has a '39 Ford body on it. Please don't tell me what a screw up this is as I am "married" to it now. I need to know how to rotate the hydraulic control unit on it. It will make line hook-up much easier. Hope this is possible. Thanks in advance. Steve
Old 04-11-2013, 08:34 PM
I got the rack on the bench today and fiqured out how to change the location. The hydraulic control is held in place with two plastic rivits, 180 degrees apart. Drilled them out, put the iron control unit in the vice and turned the rack to make the hoses point where I wanted them to. Will disassemble it further when I am through with mock-up to see if I need to drill new locater holes for the rivits. Steve
Radiator-Condenser Orientation ?'s ZipZ28 General Rodding Tech 4 04-03-2014 01:30 PM
A/C condenser orientation cboy General Rodding Tech 9 12-06-2010 05:46 PM
Distributor orientation? frankenvette Engine 4 11-26-2007 04:39 PM
ladder bar orientation AngliaBob Suspension - Brakes - Steering 2 06-16-2007 04:53 AM
Changing sanding blocks, when changing grits, is this good or bad? Ripped Body - Exterior 2 02-06-2007 03:47 PM
