changing out a 318 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-14-2006, 02:15 PM
changing out a 318
Hi, my 74 Dodge Dart Custom currently has a 318. I was wondering what other size engines would fit? Probably a basic question but I'm new. Thanks!
Old 12-14-2006, 03:15 PM
DeathRattle's Avatar
Some Punk Kid
Are you looking for a clean swap or having to customize? 360 would fit for sure. But I am also pretty sure you could get a 440 between the fenders with a few modifications. I personally know a guy with a 528 BB Mopar in a late 80s shadow. Where theirs a will theirs a way.
Old 12-14-2006, 03:55 PM
Wiki Edits: 49
A 340 or 360 will be pretty much a bolt in. Installing a B/RB block (383/400/440) will take a little more work but is manageable. Going with a big block will require other changes as well.... such as trans and rear end but it is doable.
Old 12-14-2006, 04:36 PM
cabowabo's Avatar
big Q
just pump up the 318
these 318 cant be pump up real nice with juice
Old 12-14-2006, 11:05 PM
Crazy Mopar Guy's Avatar
360 is a relative bolt in. The 360 is EXTERNALLY balanced, so a 360 harmonic balancer and a torque converter weighted for a 360 must be used- 904/999 or 727.
Pans don't interchange, but if you have entire cores it wouldn't matter anyways. One side motor mount will need a 3/8" to 1/2" shim on the 360 replacing a 318, other than that it's pretty straight forward...
Apple or orange?
' 85 318 ? knighthawk Engine 12 01-15-2007 07:13 AM
318, good for what? camino_man Engine 3 02-08-2006 05:27 AM
What is involved in Changing Camshafts? rick458 Engine 12 01-27-2005 07:56 PM
Questions about a Dodge 318 RatFink9293 Engine 2 06-16-2003 07:49 PM
oil pan for 318 mopar oldnable Engine 1 08-22-2002 01:52 AM
