Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Changing out Ford 9 inch Gears
Old 10-23-2009, 11:40 PM
WDCreech's Avatar
WDCreech WDCreech is offline
Grumpy Old Goat Herder
Be sure to check to see that the 4.30s have the same spline pinion. It will be either 28 or 35 spline. The bearing and the support are different for each, but it's no problem. Just buy the correct bearing and support and the correct pinion yoke.
