Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Changing out Ford 9 inch Gears
Old 10-24-2009, 12:50 AM
prostreet6t9's Avatar
prostreet6t9 prostreet6t9 is offline
Differential/Driveline
One other thing. 430 and 456's are the ratio's that the inside of the ring gear hit's the pocket Brg. When shopping,ask the supplier if the ring gear has the cut to clear the pocket brg with lower ratio's. All the Richmond sets usually have it. I've had quite a few Precision set's also. If you have to clearance the pocket only take as much as you have to.That's one of the places that diff likes to break.
