Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Changing out Ford 9 inch Gears
Old 10-24-2009, 12:41 PM
prostreet6t9's Avatar
prostreet6t9 prostreet6t9 is offline
Differential/Driveline
Yes! But it's the second one listed. Not on the backside,the backside cut is just for saving weight.You see how the point is rounded off at the bottom of ring gear the tooth? The first listing is a PRO gear set. I'm thinking you dont need a PRO set. That Pro set looks pretty rough anyway.
