Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Changing Output Shaft in 700r4
Old 02-29-2012, 01:58 AM
mmerlinn mmerlinn is offline
Wiki Edits: 85
The shortest output shaft for a 700 is too long to use with the standard OEM adapter housing for the 203. You will either need to make an output shaft or fabricate an adapter, unless someone already makes them aftermarket.
