-   -   Changing Output Shaft in 700r4 (http://www.hotrodders.com/forum/changing-output-shaft-700r4-215649.html)
rickvz1 02-28-2012 07:14 PM
need to change out Output Shaft in 700r4 to work with np203 transfer case
mmerlinn 02-29-2012 01:58 AM
The shortest output shaft for a 700 is too long to use with the standard OEM adapter housing for the 203. You will either need to make an output shaft or fabricate an adapter, unless someone already makes them aftermarket.
Crosley 02-29-2012 05:06 AM
Call / Email Advance Adapters for this conversion.
