Changing Output Shaft in 700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2012, 08:14 PM
need to change out Output Shaft in 700r4 to work with np203 transfer case
Old 02-29-2012, 02:58 AM
Wiki Edits: 85
The shortest output shaft for a 700 is too long to use with the standard OEM adapter housing for the 203. You will either need to make an output shaft or fabricate an adapter, unless someone already makes them aftermarket.
Old 02-29-2012, 06:06 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Call / Email Advance Adapters for this conversion.
700r4 output shaft JTGochenour Transmission - Rearend 1 02-08-2012 06:26 PM
700r4 output shaft splines mitcht2005 Transmission - Rearend 1 05-18-2011 07:07 PM
700r4 loose output shaft jacko3 Transmission - Rearend 5 10-15-2009 01:36 PM
700r4 output shaft swap pwchevyman1990 Transmission - Rearend 5 12-07-2008 11:00 AM
Changing Output Shaft in 700r4 70bird Transmission - Rearend 12 12-05-2006 06:15 PM
