Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Changing pan gasket on 350 chevy
Old 07-22-2005, 06:43 PM
ronb's Avatar
ronb ronb is offline
Originally Posted by rapsag
Mark, that makes me feel better about the possibility. As for the other note about getting over the caps and oil pump, it should not be a problem since I would be bringing the gasket up under the pan and then slipping it over the pan edges which should work because of the elasticity etc I described. Would have to get it above the pan edges on one end first then work it around the other end. My only concern is dropping any debris into the pan would screw up the whole job. Especially if it was too large to flush out of the drain. Since this gasket is presumed not to be burnt and cracked, that should help, but what if it is fused on with gasket cement? Help!
Let us know how it goes!
