Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Changing pan gasket on 350 chevy
Old 07-23-2005, 01:10 PM
454me 454me is offline
Originally Posted by rapsag
Also would have to remove the hood, and carb. Also, the fan shroud has two supports bolted to it to hold up the modified radiator reservoir that sits atop the radiator.
Why would you have to remove the hood and carb and fan shroud? If you take the fan off you can leave the shroud on. I put a 2x6 under the pan remove the motor mount bolts and lift the motor with a floor jack. Then put a piece of 4x4 about 6 inchec long between the motor and the mount. Let the jack down and you have room enough to get the pan off. Watch out for the dist. cap hitting the fire wall. Thats the only other thing I can think of.
