Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Changing pan gasket on 350 chevy
Old 08-02-2005, 01:32 PM
Henry Highrise's Avatar
Henry Highrise Henry Highrise is offline
Lost in the 60's
Wiki Edits: 4
If you have drops of oil coming out the little hole in the bottom of your flywheel cover like you say you do...and the rear of the pan is dry like you say it is...your oil pan gasket isnot leaking...It is your rear main bearing seal that is leaking.
