We're winning the case!
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 05-22-2007, 04:33 PM
ILLJim ILLJim is offline
Changing pinion bearings on Chevy
I bought a used ring and pinion for my Chevy truck. It is a Chevy 10 bolt 8.6". It came with bearings pressed on the pinion and the race for the bearings I bought do not fit. It appears that putting the new bearings on will change my pinion depth. Can I change the bearings, and if so, which spacers do I use? (spacers for my old pinion or for the new one?)
Any help would be appreciated.
Thanks.
Old 05-22-2007, 05:11 PM
johnnya johnnya is offline
Use the shims that are already on the pinion.
If the correct bearing is used to replace the old one, the depth should remain the same.
JA
Old 05-22-2007, 06:57 PM
Vortech 4.3's Avatar
Vortech 4.3 Vortech 4.3 is offline
jack of all trades
true, use the same shim
if the new race is different, i would suspect a wrong part. recheck your new parts.
Old 05-23-2007, 08:42 AM
lmsport lmsport is offline
Use the shim that was factory installed in your housing. Most gears are about the same and the bearings are the same within .00005" tolerance but the housings are not a tight tolerance, hence the shim under the rear bearing.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Changing pinion bearings on Chevy"
Pinion Angle? Again? oldskools10 Transmission - Rearend 7 01-27-2007 01:48 PM
Axle Housing Install - Pinion Angle Help leejoy Transmission - Rearend 3 01-08-2007 02:06 PM
Rack and pinion in 59 chevy? Bill Yarbrough Suspension - Brakes - Steering 4 06-12-2006 07:00 AM
Chevy 8.2 Pinion Nut MI2600 Transmission - Rearend 3 04-20-2006 06:17 AM
12 bolt Chevy truck pinion question Gametech Transmission - Rearend 9 03-09-2004 05:02 PM
