Changing pinion yoke - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2008, 06:37 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
I have a little conundrum. I am doing a whole driveline swap in a 96 Impala SS from stock to a 383, modified viper T56, and 4.10 gears. Its going to have to happen in stages unfortunately because my rear axle bearings decided to start growling at me. So the 4.10s are going in next week while its apart anyway, then the rest will happen later.
I want to do 1350 ujoints, so it makes sense to put the 1350 pinion yoke on while its apart, but then I'll have to temporarily use an adapter Ujoint until I put in a new fabricated driveshaft after the T56 goes in. So, I thought I'd wait on the 1350 pinion yoke until later, but after the crush sleeve is installed you can't do that right? Wont it change the pinion depth when I retorque the yoke?
What would you folks do?
Old 01-28-2008, 07:31 PM
Vortech 4.3's Avatar
jack of all trades
rebuild it the way you want to now. then when you swap. just replace the crush sleeve and yoke. no big deal.
Old 01-29-2008, 02:40 PM
Its not a big deal and has been discussed here before if you want to search for the details on the procedure. I would rather get the 1350 yoke now and run the conversion joint. I think your rear joint is a Mech 3R which very similar to a 1350.
Old 01-29-2008, 05:15 PM
curtis73's Avatar
Wiki Edits: 16
Oh.. OK. I assumed it was a 1310 stock but I guess I don't know why I thought that.
I'm just a fan of overkill. Its probably going to be somewhere around 400 hp at the flywheel so its not necessary, but it would be nice.
swapping the pinion yoke? Double_v23 Transmission - Rearend 8 01-10-2008 11:24 AM
Ford 9 Inch pinion yoke length?? baddbob Transmission - Rearend 15 05-31-2007 11:40 AM
Pinion Angles and Driveline Setup for the Street Centerline Suspension - Brakes - Steering 32 05-11-2007 07:22 PM
Help Removing Pinion Yoke - GM 10-Bolt leejoy Transmission - Rearend 2 11-10-2006 08:12 AM
Pinion yoke weight??!! catscan4free Transmission - Rearend 0 01-28-2004 07:25 AM
