Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - changing from points to electron ingition
Old 09-10-2004, 12:33 AM
fordred1 fordred1 is offline
New Member
I would like to know how to change the ignition on a 1972 ford 390 , to electronic ignition. Can you us the distributer from a later model engine that is all ready equipped with electronic ignition? or do you need to change the guts of the original distributer, and if you need to , can you use the electronic module from a later model vehicle ( the vehicle is a 1979 ford pickup that I what to install the 390 in ). So if you folks can help me that would be appreciated. Thank you.
