-   Introduce Yourself (http://www.hotrodders.com/forum/introduce-yourself/)
-   -   changing from points to electron ingition (http://www.hotrodders.com/forum/changing-points-electron-ingition-47460.html)
fordred1 09-09-2004 11:33 PM
I would like to know how to change the ignition on a 1972 ford 390 , to electronic ignition. Can you us the distributer from a later model engine that is all ready equipped with electronic ignition? or do you need to change the guts of the original distributer, and if you need to , can you use the electronic module from a later model vehicle ( the vehicle is a 1979 ford pickup that I what to install the 390 in ). So if you folks can help me that would be appreciated. Thank you.
Blown79 09-13-2004 05:25 PM
You can do it either way, factory ford stuff wich is great, or pertronix kit in you old dizzy. What kind of 79 do you have? I have a 79 f 150 short bed custom, 351/np435/np205 4in lift 35 MTs:thumbup:
KULTULZ 09-14-2004 04:30 AM
The 79 pickup will have the DURASPARK II System. It is the correct one for retrofit.
http://www.mustangsteve.com/DurasparkFORDall.jpg
The next schematic shows using a TFI (E-Coil) and gaining even more spark energy.
http://www.sierrabronco.com/DuraSpark.jpg
