changing from points to electron ingition - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 09-09-2004, 11:33 PM
New Member
I would like to know how to change the ignition on a 1972 ford 390 , to electronic ignition. Can you us the distributer from a later model engine that is all ready equipped with electronic ignition? or do you need to change the guts of the original distributer, and if you need to , can you use the electronic module from a later model vehicle ( the vehicle is a 1979 ford pickup that I what to install the 390 in ). So if you folks can help me that would be appreciated. Thank you.
Old 09-13-2004, 05:25 PM
Blown79's Avatar
WTH
You can do it either way, factory ford stuff wich is great, or pertronix kit in you old dizzy. What kind of 79 do you have? I have a 79 f 150 short bed custom, 351/np435/np205 4in lift 35 MTs
Old 09-14-2004, 04:30 AM
aka Duke of URL
Arrow
The 79 pickup will have the DURASPARK II System. It is the correct one for retrofit.
The next schematic shows using a TFI (E-Coil) and gaining even more spark energy.
« Hey all!! | New Guy »
