Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Changing Power Steering Pump HELP
Old 01-14-2013, 07:35 PM
LATECH's Avatar
LATECH LATECH is offline
Innerds should fit OK. As long as pump has bolt bosses for the mount brackets. The 82 will have metric fasteners and the early one will have SAE. Be sure to keep the valve/fitting from the original pump from the 82 as the fitting for the hose will probably be for an O ring and the early pump will be flare (most likely)
Fact is stranger than Fiction
