-   -   Changing Power Steering Pump HELP (http://www.hotrodders.com/forum/changing-power-steering-pump-help-228359.html)
the82elco 01-13-2013 07:33 PM
OK I HAVE A 1982 EL CAMINO I WANT TO CHANGE MY POWER STEERING PUMP TO THE KEYWAY STYLE. WILL I BE ABLE TO JUST BUY A 74 KEYWAY PUMP AND INSTALL IT INTO MY 82 Reservoir:confused::confused:
LATECH 01-14-2013 07:35 PM
Innerds should fit OK. As long as pump has bolt bosses for the mount brackets. The 82 will have metric fasteners and the early one will have SAE. Be sure to keep the valve/fitting from the original pump from the 82 as the fitting for the hose will probably be for an O ring and the early pump will be flare (most likely)
