Changing Power Steering Pump HELP - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2013, 07:33 PM
OK I HAVE A 1982 EL CAMINO I WANT TO CHANGE MY POWER STEERING PUMP TO THE KEYWAY STYLE. WILL I BE ABLE TO JUST BUY A 74 KEYWAY PUMP AND INSTALL IT INTO MY 82 Reservoir
Old 01-14-2013, 07:35 PM
LATECH's Avatar
Last journal entry: New Gas Tank
Innerds should fit OK. As long as pump has bolt bosses for the mount brackets. The 82 will have metric fasteners and the early one will have SAE. Be sure to keep the valve/fitting from the original pump from the 82 as the fitting for the hose will probably be for an O ring and the early pump will be flare (most likely)
Fact is stranger than Fiction
power steering pump for sbc with MustangII power rac TheCiscoKid Suspension - Brakes - Steering 5 12-29-2012 05:39 PM
power steering pump help, please steve t Suspension - Brakes - Steering 3 08-15-2008 05:50 PM
power steering pump oldmanchopper Suspension - Brakes - Steering 1 03-11-2008 03:04 PM
power steering pump as a secondary oil pump? lowROLLERchevy Engine 17 06-04-2007 03:02 PM
changing manual steering to power on 63 Chevy II Mustangsaly Suspension - Brakes - Steering 10 07-19-2005 04:21 PM
