changing pushrods? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2004, 03:55 PM
Muscle car fan
changing pushrods?
can i just take off the rocker arms and drop them in, or would i need to remove the intake/carb/wiring ect
engine is a 351W
'74 Gran Torino Project
351W, c6 trans, 9"
Old 07-15-2004, 04:18 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
the push rods came out of my 289 with the rockers removed and the heads still on.... only difference is the deck height....
Old 07-15-2004, 04:35 PM
71 c-10's Avatar
just a kid and his truck
exactly what larry said. The only reason i could see that you would wana take your intake off is to see that both lifters are completly closed, but knowing what stroke at least on of the pistons is on before you start, and your firing order, should make valve adjusment just fine with the intake on.
Old 07-15-2004, 05:22 PM
Aaaa... I dont know.. well, sometimes you can get away with just swapping out the pushrods, but on high mileage engines you have to worry about the new pushrods going through the rockers. Would replace the pushrods, rockers, and fulcrums/pivots. But who knows, it might work out fine.
Old 07-15-2004, 05:26 PM
Muscle car fan
i'm replacing the rockers, that's why i'm replacing the pushrods as well.
using comp high energy pushrods, and the magnum roller tipped rockers
351W, c6 trans, 9"
Old 07-15-2004, 05:36 PM
while your at it and if you have the money, go for the full roller rockers. There was an article awhile back about just using roller tip rockers and it said they did'nt help much. While the full roller rockers freed up something like 15 HP. Think the article was even in a post here.
Anyway, cool, good luck!
Old 07-15-2004, 05:49 PM
Muscle car fan
got them sittin here in my hand allready, i went with the roller tipped because i could get them in a 1.7 ratio
there are alot more things i need to worry about as far as performance/economy before i start reducing friction
351W, c6 trans, 9"
