Changing ratios in a manual trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2012, 07:48 PM
junkyardjeff's Avatar
I have one of those 4 speed with overdrive trans from a 80s ford van that looks identical to a toploader that I would like to put in my 65 galaxie,I presume its like the others and has too much of a gear spread between 2nd and 3rd. Do anyone know if I can change it to where there is a more even spread between the gears.
Changing from electric to manual choke zola_boy_7 Engine 9 02-25-2012 12:48 PM
Changing from a TH350 to a manual ss34coupe Transmission - Rearend 2 11-07-2005 08:43 PM
changing manual steering to power on 63 Chevy II Mustangsaly Suspension - Brakes - Steering 10 07-19-2005 04:21 PM
changing gear ratios the ernster Transmission - Rearend 1 02-25-2003 08:37 PM
Changing to an auto from manual in 57 Chev pikalpha Transmission - Rearend 3 12-14-2001 05:30 AM
