Changing rear end gears? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2007, 11:03 PM
Last journal entry: YAY NEW $800 CAR NOW GET TO FIX IT
Ok i have a 85 cutlass stock 7.5 rearend, want to change to 3.23-3.43 gears and not spend a lot of money, would it be better to find a rear end from a junk yard or buy the gears and switch them out? I dont know how to change the gears never done it, i could change a rear end i know but if i went to pull-a-parts how would i know which rearend to get? with my luck i would get something with gears that sucked more than what i got now
Old 10-04-2007, 11:42 PM
strummin67's Avatar
Violating consensual reality
Last journal entry: Taking a short break
Hello. You might try calling shops that specialize in rear end repairs and find out whats available for your set up. I don't know what your plans are but the 7.5 may not be able to handle a lot of power.
Old 10-04-2007, 11:43 PM
it should be able to handle a mild 403 i think, i would like to have the 8.5 that came in the GNs but i have heard they are expensive
Old 10-04-2007, 11:47 PM
strummin67's Avatar
Cutlasses are G-bodies aren't they? I think they shared some suspension parts with Grand Prix, Monte Carlos and Regals. You might be able to swap a bigger rear out of one for a reasonable amount of money.
Old 10-04-2007, 11:48 PM
the only G bodies that had 8.5 was the grand nationals
Old 10-05-2007, 12:19 AM
Chopt 48's Avatar
I'd hunt the complete rear end and swap it out.
That would be easier and less expensive than trying to set up a used set of gears in your housing.
Find a local wrecking yard that has an interchange manual that covers your car and tells what rear ends will swap over to it. Then it is the hunt to find the one with the right gears. You are probably looking for a car that came with an overdrive transmission to find the correct rear end. A little snooping might give you a good idea of which cars were most likely to come with the right ratio.
Old 10-05-2007, 12:21 AM
i know i can get one out of a monte, cutlass, regals, grand nationals(if u could actually find one in a junk yard). I have heard that the montes came with 3.73s i dont want something that high though, i have a 350 trans and actually want to drive on the highway
Old 10-05-2007, 12:17 PM
Chopt 48's Avatar
it will take either poking your head under cars and checking the tags on the rear if they are still there, pulling the covers and counting teeth or putting in a request for that specific gear set and having them pull the rear end.
Here's a link to another forum with this same subject
http://gbodyforum.com/viewtopic.php?...er=asc&start=0
Old 10-05-2007, 01:11 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
Here is a link to an axle code chart that will help in the search of the right gears.
http://www.maliburacing.com/rear_axle_codes.html
Rear end gears 69chevytime Transmission - Rearend 5 12-14-2005 02:13 PM
anybody take a guess what my rear end gears might be? smlblcks10 Transmission - Rearend 7 04-22-2004 11:46 AM
65 Chevy Rear End Gears mweber Engine 3 01-03-2004 04:05 PM
Using used rear end gears? good or bad Dubz Transmission - Rearend 5 11-17-2003 07:46 PM
66 Ford Mustang rear end gears 66StangBoy Transmission - Rearend 3 11-18-2002 06:22 PM
