Changing rear end gears... - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-23-2002, 02:24 PM
chevyelc81's Avatar
Post Changing rear end gears...
Ive got a 1969 camaro with 2.73 rear end gears. I want to get 3.73 gears but at the bottom of the list of gears, it says; "When replacing stock stock 3.00 and numerically lower, the carryer must be replaced with a carrier 3.08 or higher". Does that mean I have to replace the whole posi unit???? They sell ring gear spacers, can I use a spacer instead of replacing the whole carrier? Or do they sell gears that will fit my carrier? Any info will help, thanx.
Old 07-23-2002, 07:52 PM
axle bastard's Avatar
you're killin me buck!
Post
you should be able to use a spacer, i have intalles maybe 1,so if i need to be corected, please do.
im the bastard, NOT the master.
