Changing sanding blocks, when changing grits, is this good or bad? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2007, 02:23 PM
Ripped's Avatar
Last journal entry: First RoadCourse Video
When I blocked my rear quarters, I used a 16 1/2" sanding block (40 grit) to get the rough shape.
Now that I am switching to finer grits, I switched blocks to a 16 1/2" durablock assuming that it will flex with the contour shapes and not cut into the panel when I don't want it to.
What do you think, is this a good strategy or not? The durablock does not flex a lot. I am guide coating with the fills as well.
The only mistake I made so far was thinning the rage with unwaxed resin. Not a good idea, as it gathers on the sandpaper and clogs it.
Old 02-05-2007, 03:57 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Sure is a lot more convenient to not have to change paper on a block all the time..that is why I have accumulated a selection of sanding blocks..
Sam
Old 02-06-2007, 04:47 PM
BIGSKY's Avatar
See project in Photo Album
I am using that that flat 16" Durablock on my project. I think it works great for blocking.
Jokes Bad?? No Humor Good?? TurboS10 Hotrodders' Lounge 42 01-02-2005 11:18 AM
305 good or bad murraydavidson Engine 2 06-02-2003 09:02 PM
flexable sanding blocks Maverick Body - Exterior 7 04-10-2003 12:58 PM
are 2 Bolt Blocks good? 2506CYL Engine 11 01-15-2003 07:03 AM
good news! it's a boy!, Bad news, an ugly messy cesearian! bullheimer Engine 13 08-15-2002 09:16 AM
