Changing starter on 66 Chevy II - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2012, 06:22 PM
I am changing from stock starter to a mini-starter, and need to figure out how to wire it. Can someone help me please!
Old 10-07-2012, 07:00 PM
vicrod's Avatar
life is a ride
Last journal entry: LED tail lights
Same as the stock starter.
vicrod
Old 10-07-2012, 07:51 PM
Thank you for your reply, he is out in the shop right now, but I told him your responce and he says no they aren't wired the same.
Old 10-08-2012, 03:49 AM
EOD Guy's Avatar
He's prob talking about the "I" terminal on the 66, the new mini prob doesn't have it.
The "I" terminal on the starter goes to the coil and provides a full 12v when the engine is cranking. After it starts the "I" terminal goes dead and the coil recieves 9ish volts via a resistance wire. A constant 12v to the coil will burn it up.
Modern HEI systems do not require the "I" terminal because it uses 12v all the time.
You can wire in a simple relay to provide the missing "I" terminal voltage or switch to an HEI system. I'll draw up the wire dia if you need it.
starter, wiring
Changing pinion bearings on Chevy ILLJim Transmission - Rearend 3 05-23-2007 08:42 AM
Changing sanding blocks, when changing grits, is this good or bad? Ripped Body - Exterior 2 02-06-2007 03:47 PM
Changing pan gasket on 350 chevy rapsag Engine 16 08-04-2005 07:55 AM
changing manual steering to power on 63 Chevy II Mustangsaly Suspension - Brakes - Steering 10 07-19-2005 04:21 PM
changing frames for a 51 chevy 2 door. KB Suspension - Brakes - Steering 0 11-20-2001 08:28 AM
