Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Changing Steering
Old 10-25-2011, 01:28 PM
35terraplane's Avatar
35terraplane 35terraplane is offline
Steering
Originally Posted by 1brewmaster1
Good DAy All...
I have a defective mustang 2 manual rack in my truck and plan to change to power steering.
Is there a difference between a Mustang 2 rack (70's vintage) and a Mustang rack '94 vintage. They look the same, have the same length measurement and will mount the same with off set bushings.
Thanks for your input. Richard
You didn't say what truck you have, it sounds like something you put a Mustang II front suspension on. I'm not sure about the Mustang racks, but I know that the 87 T-Bird racks, on up are different. If you have a GM pump you don't have to reduce the pressure, that is the rack Speedway sells. You also need to know if you have 2 or 3 mounting bolts.
If you are running a newer Ford pump, with the rack you don't have to worry. I would check with a dealer to make sure if the rack will work with your pump.
Bob
