Changing Steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2011, 11:03 AM
Changing Steering
Good DAy All...
I have a defective mustang 2 manual rack in my truck and plan to change to power steering.
Is there a difference between a Mustang 2 rack (70's vintage) and a Mustang rack '94 vintage. They look the same, have the same length measurement and will mount the same with off set bushings.
Thanks for your input. Richard
Old 10-25-2011, 01:28 PM
35terraplane's Avatar
Steering
Originally Posted by 1brewmaster1
Good DAy All...
You didn't say what truck you have, it sounds like something you put a Mustang II front suspension on. I'm not sure about the Mustang racks, but I know that the 87 T-Bird racks, on up are different. If you have a GM pump you don't have to reduce the pressure, that is the rack Speedway sells. You also need to know if you have 2 or 3 mounting bolts.
If you are running a newer Ford pump, with the rack you don't have to worry. I would check with a dealer to make sure if the rack will work with your pump.
Bob
Old 10-25-2011, 06:04 PM
Reply re Changing Rack
Thanks Bob for your response...
Yes it is a modified truck with a Mustang 2 front end. There are two mounting bolts that are 16 center for the manual rack and 15.5 for the power rack. This will require offset bushings to fit the power rack to the cross member. The only difference I can see is that the shaft on the manual rack has splines with a 9/16 shaft. On this power rack it is slightly less then 3/4 and no splines. The DD shaft will have to be modified for fitment. My major concern is the ability for this power rack to do the job with all the weight on the front end. The Mustang 2 systems had V-8 engines that were heavy while in 1994 Mustang everything was much lighter.
Old 10-26-2011, 09:54 AM
Steering
I don't think the rack will have any trouble with the weight, as about all you can buy, are the newer ones. you just have to get a u-joint to fit the rack on one end and the DD on the other.
Bob.
Changing sanding blocks, when changing grits, is this good or bad? Ripped Body - Exterior 2 02-06-2007 03:47 PM
changing manual steering to power on 63 Chevy II Mustangsaly Suspension - Brakes - Steering 10 07-19-2005 04:21 PM
Putting on new air bag steering wheel on a older steering collumn. CruisingRam Interior 10 12-20-2004 03:34 AM
Changing cam? TVR383 Engine 2 09-11-2004 06:29 PM
Power steering chatter in steering wheel jpd37 Suspension - Brakes - Steering 10 05-19-2003 03:59 AM
