Changing from a TH350 to a manual - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2005, 10:16 PM
Ok heres what I have, I bought a '33 coupe all steel, it now has a 355 with a TH350. I am wondering if a muncie will bolt in with out making any changes to the trans crossmember, I ask this cause I once owned a '63 impala and changed it from a powerglide to a munci 4 speed using tha same crossmember and even trans mount.
Old 11-03-2005, 10:51 PM
poncho62's Avatar
Wiki Edits: 5
Yes....it should mount up the same spots.......your biggest problem is going to be fabricating the clutch linkages etc....unless you go hydraulic...or a cable.
Old 11-07-2005, 08:43 PM
It will bolt in if your t350 has a SHORT tail housing and you use a coarse spline muncie. Stay away from close ratio (2.20 1st) boxes, your clutch will thank you.
TH350 Manual Valve Question Pantload Transmission - Rearend 6 02-19-2006 01:48 PM
TH350 Manual linkage position (picture) pcesak Transmission - Rearend 5 03-15-2004 03:53 AM
th350 1st gear manual shift problem desman Transmission - Rearend 6 02-08-2004 03:15 PM
th350 manual valve body on STREET? MuscleBlock81 Transmission - Rearend 2 10-30-2003 08:46 AM
Changing to an auto from manual in 57 Chev pikalpha Transmission - Rearend 3 12-14-2001 05:30 AM
