Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Changing trailer tires
Old 04-10-2005, 08:34 PM
Rob Keller's Avatar
Rob Keller Rob Keller is offline
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
mobile home tires
are you talking about mobile home tires & rims has a bolt or stud and a square wedge/washer that hold the rim to the hub??
if u do replace the hub Assembly to use a regular tire and rim
those mobile home things are a wreck that just hasn't happened yet
sr66
ps the life you save could be you own
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
