Changing Wheel Studs - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2004, 10:07 PM
MI2600's Avatar
Member# 3287
I picked up a 12 bolt rear end for my '67 Chevy. The guy who had it replaced the original length studs for longer ones, for racing.
I've never had to mess with them before. Anyone have any easy way to press out the old studs while it's all assembled? Or, will I have to pop the axles?
Old 09-13-2004, 10:40 PM
E.T. divided by $ spent= Speed
If ya don't wanna save the long ones just wack um off with a cutoff wheel and knock um out with a punch and a ballpeen hammer.
Old 09-14-2004, 03:22 PM
club327's Avatar
The easy method I use is to grab a mash hammer and hit the stud full on square. Amzingly they pop out easily when u hit them with conviction and the threads remain undamaged.
Old 09-14-2004, 09:59 PM
MI2600's Avatar
Member# 3287
Hey Club,
I'm assuming a "mash" hammer is defined as "big", "heavy", "massive", or "sledge"?? Or, maybe all of the above?
It's funny how two peoples who speak English are divided by the common language...Did Churchill say something like that?
Thanks
Old 09-15-2004, 12:08 PM
fat50's Avatar
Kenneth Howard hates me...
Last journal entry: Engine mock up
If you do deside to cut the shorter, Do it with a nut already in the stud. When you remove the nut from the shortened stud, it will stand the threads back up. Good luck starting a lug nut on a stud that has had the first thread wacked.
I wonder if you could put a hole in the backing plate to get the studs in and out with the axles in, than plug it (kinda like a big adjuster hole?)
Old 09-15-2004, 07:47 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
MI2600, why do you even want to remove them?
Old 09-15-2004, 10:04 PM
MI2600's Avatar
Member# 3287
Ghetto,
I've got the Chevy rallye wheels on the '67 and I used the short center caps instead of the usual high-hat derby caps. I don't think the longer studs will fit under them.
You know now that you mention it, I might save some grief and see if they do fit. Golly Gosh, I'm glad I thought of that!!
Old 09-16-2004, 08:26 AM
Ghetto Jet's Avatar
