Channled, Sectioned question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2002, 08:35 AM
Post Channled, Sectioned question
Hey folks I am a first time Rod Builder and need an explanation of what channeling and sectioning means. I am building a 47 Chevy sedan delivery and after I saw Pat Keating's 48 Chevy in Street Rodder Jan 2002 issue I have decided that I will need to do more work to properly express my self and I need to understand the terminology.
Also dose anyone know about working with aluminum, I know when you heat it become real workable. How do you make it regain it's stiffness or strength? Possible by placing in cold water while hot?
Happy Hot Rodding
Old 01-31-2002, 04:19 PM
Post
A simple explanation is channeling is lowering the body over the frame, sectioning is taking part of the body out to shorten its height,similiar to chopping a top.
Old 02-05-2002, 02:30 PM
New Member
Post
Dan: I have read a book on using aluminum and believe most of the shaping is done cold. Frequently wooden bucks are built as a support for the panels while in process. You won't find a lot of hot rodders using aluminum because welding it is a problem. It is difficult to wire feed aluminum because the wire is too soft to "push" well. A wire spool at the gun instead of at the machine is used professionally. I think most aluminum is tig welded for structural components. I guess I didn't really answer your question.
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 07:35 AM
Switching to 200R Tranny question Gundarak Transmission - Rearend 4 12-05-2003 08:00 PM
nitrous 69BiRd Engine 2 11-28-2003 10:33 PM
