-   -   Charcoal Fuel Vent Canister! (http://www.hotrodders.com/forum/charcoal-fuel-vent-canister-226286.html)
Curmudgeon29 11-19-2012 10:35 PM
Does anyone know of a very small charcoal canister that I could fit to a 1/4" gas tank vent line hose to keep the smell out of the garage? Thanks for your suggestions!
gearheadslife 11-20-2012 12:37 AM
iirc fords (some) had a a few the size of like 8x7x3
most g.m. are round..
Pre-Tuner 11-20-2012 07:47 PM
Put a "U" in the hose with the open end pointing down. The vapors get trapped in the top part of the "U" while still allowing it to vent like you want. The hose needs to be higher than the tank also, but that usually isn't a problem.
That worked for me.
lakeroadster 11-20-2012 07:53 PM
Is your engine carbureted? If so a lot of the smell is likely coming from fuel evaporating from the fuel bowls.
