Charcoal Fuel Vent Canister! - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2012, 10:35 PM
Curmudgeon29's Avatar
Now that wasn't so easy!
Does anyone know of a very small charcoal canister that I could fit to a 1/4" gas tank vent line hose to keep the smell out of the garage? Thanks for your suggestions!
Old 11-20-2012, 12:37 AM
gearheadslife's Avatar
MentalMuffinMan
iirc fords (some) had a a few the size of like 8x7x3
most g.m. are round..
Old 11-20-2012, 07:47 PM
406cu.in. of tire smokin' fun
Last journal entry: 406 Build Thread
Put a "U" in the hose with the open end pointing down. The vapors get trapped in the top part of the "U" while still allowing it to vent like you want. The hose needs to be higher than the tank also, but that usually isn't a problem.
That worked for me.
Old 11-20-2012, 07:53 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Is your engine carbureted? If so a lot of the smell is likely coming from fuel evaporating from the fuel bowls.
The Following User Says Thank You to lakeroadster For This Useful Post:
Curmudgeon29 (11-25-2012)
Charcoal Canister bentwings General Rodding Tech 20 08-14-2007 07:56 PM
Charcoal canister-removal ? stinky jinx Engine 3 08-20-2004 06:07 PM
Charcoal canister-2nd try.... stinky jinx Engine 5 07-25-2004 10:24 PM
Charcoal Canister Question Jag Daddy Engine 0 04-16-2004 04:53 PM
Charcoal Canister BT74 Engine 3 12-16-2003 07:00 AM
