charging issue? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2006, 08:37 PM
all show, all go with a 383
charging issue?
I think I have a slight charging issue. before I got my engine rebuilt, my alternator was charging fine at 14 volts. now after the engine is back in. the alternator only charges at 12 volts at idle and about 13.5 to 14 volts cruiseing. pulled it apart and realized that one brush doesn't sit squarely on the one sleeve of the armature. Not sure if this would cause a charging issue either, but I I'm now running the march serpentine performance pulleys on the car, they are an under drive set. If I put a smaller alternator pulley on instead of the one that is on now, will that help.
will apprecaite any information.
thanks
Dan
Old 09-03-2006, 12:01 AM
Low charge
Well if you put a smaller pulley on it, you just defeated the purpose of underdrive, which I don't like the idea of in the first place.
But yeah, as long as your amp draw at idle is above what the alternator can handle at low rpms, you're going to have an issue unless you increase the RPM's of the alternator at idle.
I hope you're sure that the voltage is above 14 at higher RPM's. Have the alternator tested at the local auto parts store for proper output just to be sure. Things aren't always as they seem.
Steve
Old 09-03-2006, 02:46 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
Since you have had it down, I would acquire an Alternator Rebuild kit and do a total rebuild..This will renew the brush kit and spring followers AND the Diode regulator...
Next is this a 1 or 3 wire internally regulated Alternator?
A 1 wire requires some initial RPM to "wake up" the regulator..So If that is your configuration , you need to return to the old pulley system OR go larger..
If it is a 3 wire Internally Regulated:
And the connection is 10 gauge red to Solenoid Battery terminal, Via Proper Fuse link, and wire #2 is jumpered to the big red output wire, and terminal #1 is Brown to the idiot lamp, you may want to try MOVING the small red #2 to the solenoid connection (or wherever all your main connections are located)
This will remotely sense a higher drop in Voltage allowing the regulator to run sooner and longer..to raise voltage readings.
We , of course assume you have followed proper ground bonding procedures already.
Happy and Safe Labor Day!
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 09-04-2006, 12:01 PM
thanks so far for the information. Did you say that you didn't like underdrive pulleys or the idea of putting a smaller pulley on the alternator. I had the alternator tested and all the autoparts store was it was still good, which didn't help me at all. the alternator is 120 amp and is a 3 wire internally regulated. should I consider tryng the reuild kit.
Charging system info............... poncho62 Electrical 11 11-26-2005 09:53 PM
2001 Ford Van Charging System NAIRB Electrical 4 06-09-2005 07:01 PM
66 Mustang charging problems. Pulling my hair out... danbeck Electrical 4 12-30-2004 09:08 AM
charging system problems mmartin1872 Electrical 3 11-07-2004 01:51 AM
capacitor? no charging? 72Nova Electrical 7 01-07-2003 11:47 AM
