Charging problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2003, 02:58 PM
New Member
Post Charging problem
Ok here's the deal. I don't think I'm getting a proper charge on my battery. I test across the post of my new Optima red top and get 10v. Start the Bronco and get 10v. I had the original alt that I suspected was the problem so I went down and had it tested and it was producing 10.5 volts. Great reason for a new alt. So I get a new alt. and install it. It's a Summit one wire internally regulated alt. Start the Bronco and now I get 11v across the posts while running. I should be in the 14v range right? What could the trouble be? I don't want to kill my new battery. I wonder if there is a problem with my volt meter...
Old 02-12-2003, 03:23 PM
5.0Towncar's Avatar
Post
Is it a mechanical or elcetronic meter? Some mechanical meters are ran off of an internal battery and maybe, just maybe the battery is going dead??? I dunno, just a suggestion. Take it down to a parts store with a meter that checks everything and let them see if they get the same thing. Steve
[ February 12, 2003: Message edited by: 5.0Towncar ]</p>
Old 02-12-2003, 06:56 PM
New Member
Post
Voltage meter was bad. Just got a new one and everything checks out fine.
