charging problem on a 66 chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-24-2003, 11:07 AM
powerglide_66's Avatar
Hello everyone
My alternator seems to be charging my battery at an excessive rate. The regulator is hooked up correctly and is brand new and so is the alternater and so is the battery. the battery is being charged at around 18 volts and looks as if the battery is going to explode. (the sides of the battery are no longer flat but are rounded)
The car will not start after a day or more. I have to get the battery starter/charger to start it. It stays running and charges the battery excessivly. I can restart the car the same day and throughout the day but tomorrow it won't start.
I recently switched back to the external-type or original alternator from an internaly regulated (SI series) alternator. and I had the overcharging thing happen with that alternator so thats why I switched back to the original. and I noticed I had the overcharging thing happed as soon as I moved from Fort worth texas to Council bluffs, IOWA. I don't know if the climate has something to do with this or not.
Thank you very much with your patience.
Old 12-24-2003, 02:32 PM
poncho62's Avatar
Wiki Edits: 5
I think that you have a short in your wiring. Its grounding out and calling for charge all the time.
I had an alternator doing the same thing. One of the fibre washers in the alternator was bad causeing the alternator to ground. It was then overcharging all the time. Replaced the washer and all was fine.
Old 12-25-2003, 06:44 AM
pappy 32's Avatar
Last journal entry: Heading home
Question???
If I understand what you are saying, you put an internal regulator alternator on and it overcharged. Then you reinstalled the original alternator that uses the voltage regulator and it still over charged.
Just a thought, when you installed the internal regulator alternator, did you unhook and plug the old external regulator? If not you may have shorted out both regulators. The one in the alternator and the one mounted on the radiator support.
You may want to get out a meter to check your polarity and continuity. This should find your problem and keep hair on your head.
Pappy
Old 12-25-2003, 08:11 AM
dmorris1200's Avatar
doesn't play well with others
A bad cell in the battery can also cause an overcharging condition, although it doesn't happen all that often. Take the battery out of the car and have it load tested by itself. If it fails replace it and then recheck the cars system with a new fully charged battery.
BUILT FORD TOUGH
Old 12-25-2003, 09:50 AM
I installed the internal regulated alternator and it worked fine in Texas until I moved back to a colder climate(Iowa) then it wouldn't start and the battery was hissing when It was being charged by the alternator(internal reg.). then I changed the alternator back and it's still doing the same thing. I went to Wally-World and exchanged the battery for a new one and it does the same thing.
thank you guys for your input
p.s. what's the difference between a regulator with a capacitor wired off of the brown wire terminal(idiot light wire) and a regulator with no capacitor at all? what exactly does this capacitor do?
Old 12-26-2003, 05:09 AM
pappy 32's Avatar
Hope this helps
I was looking around and I found a sit that might help. I have a '67 Bel-Air wagon and I learned something from this link. I hope this will help out.
The link is:
www.madelectrical.com
Then go to the Tech window
You will want to go down to Chevy Main Electrical Power Systems
This talks about Chevy muscle cars '63 -'71s. It also talks about one-wire compared to the three-wire systems, part numbers, and a lot more.
I found it informative and was surprised how important the horn relay is.
Hope this might help out.
Good luck and let us know how it all works out.
Pappy
