charging problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2007, 07:15 PM
Lilcarrin's Avatar
charging problems
Well guys i have no real clue what im doing lol
but here it is .. i have a 72 elky .. 350 .... and my battery just sucks dead in like 2 days ... so i think it doesn't get charged while the car is running or something is sucking it dry while its just sitting there .. the pre owner messed with the cables ... he cut and what not put together again .. so yeah ..
the car runs like i said its just the battery ..
Any help is good
thanks marco
Old 08-15-2007, 07:20 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
Can you borrow a voltmeter? If so, hook it to the 2 posts on the battery. Run the motor up to highway speed rpms and it should read around 14 volts. If it only reads 12 or 12.5, it is not charging at all.
Old 08-18-2007, 05:57 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
You Have the "Classic Morning sickness syndrome"... (you been parking the ol' girl next to any Vetts lately at night? )
To test the output, Start and warm the car to a curb idle..usually around 950 for stocker automatics..
Get out your DVOM and set it for DCV scale, V X 20 or higher selection, and place each probe on the battery RUNNING with NO loads..(no heater, No lights Domes, hoods , trunk, High power audio stuff, A/C, ..Nothing) It should read between 13.95 and 14.4 Volts...IF it is low..
Check the belt for wear and tightness..repair as needed..
PULL and CLEAN both battery terminals and battery cables at BOTH ends..inspect for encroaching corrosion UNDER the insulation, If found, toss them and get new...they are no good..
Restart and check again..If still low (12.5 12.0 or lower..) you may have a bad set of diodes in the alternator..
Charge the Battery, 6 to 10 Hours at 10 amps..check voltage after "Settle time" It should be around 13.95 volts..Static.
Configure your DVOM for AMPS, and the highest scale (usually about 10 amps on most mid~range home meters) , pull the battery cable and place one probe on the cable, the other on the battery...NOW, scale the reading DOWN , until it ALMOST pegs or "OL's" the readout..THIS is your true reading..
This reading should be between .3 and .8 amps (less than an amp..) to be within spec. higher indicates a draw and THE problem.
GO for the lightning round FIRST..
Remove ALL the wires from the Alternator..Retake your readings..If they fall within spec, you have some reverse biased diodes (leaking backward just sitting overnight loading the battery)
You will need to rebuild the Alternator ( Kit = $16.99 Fazools (and 2 hours of your time AND you CAN'T SCREW it up!!)..at auto zombie...Genuine Delco Replacement=159. to $300. Fazools at auto zombie..)
I JUST Did one from a Hospital bed , Non ambulatory, tubes in/tubes out.. on a feeding table, with 5 or 6 SMALL hand tools.. Took less than 30 minutes for me although I have been doing it for 40 years..but never from a Hospital bed.. ( I took photos too...and will be doing a post later on this..IF I can do it under those situations ANYONE Can do it anywhere with no knowledge, and FEW tools)
IF by chance....
The measurements Don't fall back within spec...you have a parasitic Draw on the system..
Leave your DVOM in place, BE SURE all loads are off or defeated during all tests.., pull ALL the relays and fuses..
THEN, one by one plug them BACK in until the readout jumps up..that is an offending Branch circuit..troubleshoot , correct or defeat as required on that branch circuit..then go on.. (you may have more than one draw) until all are back in place.
That will Cure Morning sickness syndrome in most cases.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 08-19-2007, 01:24 PM
Doc
Hope you are ok Doc. Get well soon.
Old 08-19-2007, 04:48 PM
docvette's Avatar
Wiki Edits: 12
Doc Here,
Thanks for your concern...
This has been going on for 3 years, now this bout....X 5 years in and out or remiss...I always manage to Spring back..
Doc
Innovations
Winter Service , Charging System... docvette Electrical 13 01-09-2007 06:51 PM
charging issue? novadan Electrical 3 09-04-2006 11:01 AM
Charging system info............... poncho62 Electrical 11 11-26-2005 08:53 PM
2001 Ford Van Charging System NAIRB Electrical 4 06-09-2005 06:01 PM
capacitor? no charging? 72Nova Electrical 7 01-07-2003 10:47 AM
