charging problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2010, 04:07 PM
charging problems
i have a 76 nova which i put a 97 vortec engine in and i am having problems getting the vortec alternator to charge not sure which way to wire it up. any help would be much appreciated.
Old 11-08-2010, 10:48 AM
kd5icr's Avatar
Camaro Guy All The Way!
I did the same thing on a 82 camaro. I did this.
The 1 wire plug on the alt I made it key on hot, the lug on the back runs to the battery. It worked like a charm and have had no problems.
Old 11-10-2010, 09:02 PM
I've tried that, it fried the alternator.
Old 11-10-2010, 10:21 PM
DOCTOR DC's Avatar
NUCKINFUTS MOTORSPORTS
its probably a cs style alternator. if you can post a pic of the connector or describe it, they are pretty easy towire up. probably a 4 wire connector plus "BAT" terminal.
Old 11-25-2010, 02:23 AM
There are two different wires that are generally needed for a CS130 to charge.
one is the "L" terminal for the warning light. this _MUST_ be used. all it needs to be is an ignition switched 12v source, run through a small 194 type light bulb and to the L terminal if you don't have some factory setup for an alternator light.
the other wire is a sense wire. simply connect it to the big stud on the back of the alternator. (There are better ways, this is just the easiest)
this is basically how I wired up a CS130 into my 1972 monte carlo, and it works _GREAT_
Old 11-27-2010, 09:55 PM
ok heres what i did, i hooked up a ignition hot to a 194 bulb then to a 20 amp fuse the to the alternator. the bulb comes on when the alternator is not charging. thank you for the advice and i hope this helps someone else out with the same problem.
Old 11-28-2010, 12:03 PM
that 20A fuse is a little big.. should probably use something more along the lines of 5A
86 S10 charging problems johnwwwwww Electrical 8 04-14-2009 07:37 PM
Charging problems?? jackndelphine Electrical 10 10-01-2008 11:16 AM
Charging circuit problems mittleiderj Electrical 1 11-15-2007 01:38 PM
charging problems Lilcarrin Electrical 4 08-19-2007 04:48 PM
Winter Service , Charging System... docvette Electrical 13 01-09-2007 06:51 PM
