charging system - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2013, 02:07 PM
charging system
How long can run your vehicle if it is over charging, charging at 16 volts?
Old 03-16-2013, 02:14 PM
poncho62's Avatar
Wiki Edits: 5
Until you boil the battery, I guess........What vehicle?...external/internal regulator?
Old 03-16-2013, 02:30 PM
charging system
Extarnal voltage reg. I've tried everything and can't get it to stay between 13.6 to 14.6 and when I can it either really aradic or jumps to 16 volts or higher?
Old 03-16-2013, 08:26 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
bad connection
The high meter readings could be caused by a bad connection of the battery cables and battery ground connections.
Clean and double check all connection to the battery. It's worth a try.
If that doesn't work have the system tested at your local Boys or Zone store.
vicrod
Old 03-16-2013, 08:32 PM
Charging System
I'll try all that you said and get back to ya in a day or two, thanks.
Charging system Rough Road Electrical 2 03-21-2012 06:04 PM
79' Gm charging system RexRat Electrical 8 09-01-2008 12:26 AM
charging system not charging i want to learn Electrical 6 02-24-2008 06:53 PM
Charging system hwyhog Electrical 4 05-22-2006 04:44 AM
Charging System Guy Hiltz Electrical 2 10-01-2005 03:20 AM
