Simple test.
There are three wires on the alt, large red, small red, and usually tan or white. Using a 12 volt light bulb, run a wire from the tan/white wire connection to the light bulb and from the bulb to the battery positive. With the vehicle running the light should go out. If it does the gage is bad. If it does not the alt is not charging.
Charging system
Docc here,
Get a DMM and measure the Voltage across the battery at Idle, after a few minutes after startup (to regain surface charge) It should be 14.4 volts and steady.. Next turn on all electrical and monitor does it hold steady at 14.4? (or no less than 13.75) If not the regulator may be the issue.. Even if the Alternator Is brand new, The failure rate out of the box on those is unacceptable..like 1 in 3 or 5...SO just being new does not take it out of the troubleshoot loop... Unless your running TONS of Electrical accessories, you should not SEE a dip in power through the lighting systems (dim, then bright Ect..) UNLESS the alternator is under-matched for a full current press... ................ ..............Doc
Aftermarket Solutions Electronic & Electrical Innovations |
| Charging system info............... | poncho62 | Electrical | 11 | 11-26-2005 08:53 PM |
| Charging System Not working | rbfpezcore | Electrical | 8 | 06-21-2005 06:52 PM |
| 2001 Ford Van Charging System | NAIRB | Electrical | 4 | 06-09-2005 06:01 PM |
| Rewiring The Charging system | 1186gibriadams | Electrical | 2 | 12-05-2004 04:59 PM |
| charging system problems | mmartin1872 | Electrical | 3 | 11-07-2004 12:51 AM |
